Xceslius 2008 connectivity With WebI Reports
Could some one give me idea whether it is possible to connect 2008 to webi reports directly ?
Also today I have installed Xcelsius Engage Server 2008 trial version , so is there any specific document available for this version ? If yes - Can some one pass on the link from where I can download it…? Thanks in Advance.
Only by using Live Office :).
Thanks Mak for your prompt response. I thought it will do directly, so I downloaded it as I found Xcelsius 4.5 bit complex to integrate with QaaWS. Is live office a free ware or it’s a licensed software ?.. I know I should search , but I would appreciate if I just get to know from you whether I need to purchase it or it is free?
Its part of Business Objects product range, so yes you need a license.
Thanks Mak. You are always on critical help. I am very thankful to you.
Now I will try to search some videos and try to understand 2008. Once again thanks a lot.
Edit - Actually Mak, I was seeing the below video and in that it is connecting directly to webi report, so the question came to my mind.
http://antivia.com/xwisxtra/vids/XWISQuickDemo.html
Well that looks like a third party add on, may be worth looking into…
After your response I thought it’s a Live office. Do you have any idea what kind of third party tool they are using ?.. I guess NO else you would have helped … :slight_smile:
Well its on their front page “Xcelsius Web Intelligence
Integration Suite (XWIS)” :wink:
Again I guess this is a licensed ware ?-- Right…
Aniket, come on put some elbow grease to it and do not expect us to do all your research, Obviously, the link is from a 3rd party vendor, so you will have to purchase that separately as it is not part of any product sold/manufacured directly by SAP/BusinessObject.
Aniketp -
Just so you know (depending on your enviornment) the release of BOE 3.1 SP2 now has a new “BI Services” capability within the Webi Rich Client tool that allows publishing of webi content via web services - similar to Live Office. We making use of these and connecting our models directly to webi reports.
Dan
dmanTX :us: (BOB member since 2006-10-30)
Andreas , thanks for your response. I apologizes for my expectations. Actually I am very new to Xcelsius , so I am not sure I am going to the right path , that’s why I take help from you guys who already had worked on Xcelsius. With your help, I do research and try to implement what is feasible.
For an eg.: Right now I am having Xcelsius 4.5 and QaaWS, so I am trying to automate all dashboads and struggling with this since 10 days. But haven’t got any success. But I really appreciate help which I am getting from all. Also I do try to search from my side , but still I will try more from my side. Once again thanks for your help.
