I have an odd issue. I developed a simple dashboard a few weeks ago that uses XML as data source (Actually three XML data files). I had only set the global security for the flash to where the files (both .swf and XML) were on my local drive. Everything was working fine (static data).
Now a request was made to move the .swf file to a web page (copied data files and the new .swf that has the correct path to the XML files to c:\inetpub\wwwroot). I has IIS installed locally and was trying to make that happen. But I got the above error and strange enough now my original .swf file is getting the error.
I even dropped a crossdomain.xml file into the wwwroot folder.
Any ideas?
kevlray (BOB member since 2010-06-23)
