BusinessObjects Board
Xcelsius using XML Data connections
I am facing difficulty in understanding how xml data connections are used in xcelsius.
Please anyone tell me the easiest way to convert excel file into XML code and then, I need to pull connections into the dashboard. Please reply if anyone has any idea on xml data connections and then I will ask few more questions based on your feedback
MR
mrkn (BOB member since 2012-03-15)
If you search right back in this forum, I posted a really handy link to a web page that takes you step by step into creating a map for your excel spreadsheet and I think I documented everything I did too in creating XML MAP connections. Look for XML MAPS in my posts.
Bit busy right now but I will search it out later if I have time.
Debbie
If you use [xml data], the excel xml might have to much info in the xml file.
Check your input file with the preview-file you can make.
Stick to and.
Make sure your range name is equel to the variable name.
IngeH :netherlands: (BOB member since 2004-06-22)
Here we go. This might help…
Debbie
Thanks Debbie and IngeH
Hi Mrkn
see the link. I hope matched u r requirement http://www.sdn.sap.com/irj/scn/go/portal/prtroot/docs/library/uuid/80473ce4-27f3-2e10-b185-a0d6eef75e3d?QuickLink=index&overridelayout=true&52849572632922
kishorebir :india: (BOB member since 2012-02-09)
