Xcelsius is compatible with 34bit or 64bit, and what are the windows version it will support…Suggestion Plz…Urgent…
Regards ,
Arul N
bosspec (BOB member since 2013-03-11)
Regards ,
Arul N
There is not such thing as 34 bits
We have no idea what Xcelsius version do you have and use. For supported version of OS, please check the official PAR document on the SAP website.
hi,
Its 32 bit…!!
we are going to install Xcelsius 2008 sp5 enterprise edition.
Check the list of supported platforms on the SAP website.
Here are steps how to navigate the SAP site:
