BusinessObjects Board
Xcelsius spreadsheet component bug?
Hi all,
If you look at the attached screenshot you’ll see that the Xcelsius spreadsheet component isn’t displaying exactly what is in my excel model. If I enter the date ‘1/Oct/2006’ in my model/spreadsheet and display this using a spreadsheet component I get the date ‘30/Sep/2006’.
It took me a long time to find this bug in my model and I can’t for the life of me work out why it’s occuring. Can someone confirm whether it’s an Xcelsius bug or a problem with my environment (Xcelsius 2008, Excel 2003, Australian regional settings)???
Any help would be much appreciated.
gcrow :australia: (BOB member since 2009-07-15)
I vaguely remember a similar issue we faced with dates in Xcelsius 4.5. Will go through my archives to confirm and also test in Xcelsius 2008.
Farhan Jaffery :us: (BOB member since 2005-08-27)
I have Xcelsius 2008 SP2 installed on XP and wanted to confirm what “gcrow” was saying. In my case it shows ######## instead of an invalid date. So i guess, there is indeed some problem with dates and after further testing i could narrow down the problem with October month dates only for e.g. 31/10/2006 also shows #######.
Could someone in other regions check this as even i am in Australia.
I will update if i get any resolution.
Viru
viru4808 :australia: (BOB member since 2008-01-09)
Was this issue occuring on an imported Excel data spreasheet into Xcelsius?
katullus :us: (BOB member since 2009-08-21)
hi there!
i think it’s a bug, because i encountered it before and it’s really hard to analyze the problem. what i did is i have a cell that get’s the date, like this: b3=today() then on a different column i pointed a cell to b3 that will be shown in an xcelsius component: c2=b3-1; c3=b3; c4=b3+1 that solved my problem.
regards,
r.A>
:mrgreen:
R.A. :philippines: (BOB member since 2008-10-28)
Thanks for your help.
FYI the spreadsheet wasn’t imported. The screenshot that I posted above is the entire model. I just typed the three dates into the cells and displayed using the spreadsheet component.
I ended up getting around the problem by using 2/Oct/2006 (as for my purposes I was only using the year and month components).
Works fine for me… May be an intermittent error.
Xcelsius 2008 sp2.
Jeswin :india: (BOB member since 2009-07-01)
I tested it…worked fine for me as well… could be an issue with your excel
I see that in the above image the font in the Excel Sheet doesn’t match with the font on the Spreadsheet component in Xcelsius.
Is there a way to make both the fonts equal.
User0207 (BOB member since 2013-09-21)
