Xcelsius exported flash not update when using XML map
I use the Excel XML map (Excel 2003) to connect XML data with my dashboard. It’s work when I update the content of data but it dont’t update when I add or remove node in XML data. (I add one record of data via XML file but flash file generated with no that record)
How should I do for to solve this problem ?
Nutchanart
ning (BOB member since 2009-05-03)
