Hello everyone, sorry for my English.
I wanted to get help for problems I have with the integration of Xcelsius and FlyNet. I have the license for Xcelsius Enterprise and FlyNet Viewer Web Service Generator (Engage Server Edition) Version 1.5.22.0.
Db excel.
I explained why every time I start FlyNet ask me the key? I put one of Xcelsius. " There are no cals installed on this server. please enter your evaluation or full xcelsius engage server key, or contact your supplier for a key.
How come when I invoke the method, after creating the web services, I released the following error message:
“No CALs installed in Flynet CAL Manager for Xcelsius. Use Flynet Viewer Web Service Generator (Engage Server Edition) to enter a new key.”
After I create the connection, enter the WSDL URL, map the fields with the spreadsheet below, put a component, but if I go to preview I released no data but only the component. All this may depend on licensing issues?
I see that nobody answered me … maybe I was not very clear! I try to simplify the problem.
I Xcelsius Enterprise with their license, but does not hold and neither QAAWS Live Office.
If I wanted to integrate with the db what can I use? Tool-free?
FlyNet only works with Xcelsius Engage Server?
FlyNet support was very clear. Virtually the enterprise version of Xcelsius does not support the tools FlyNet this folder connectivity. So either you use the “ENGAGE SERVER” or should request a new version of FlyNet (2010) who gave me a trial basis for 14 days.
This works with the enterprise.
I just write queries directly over the database, then make an aspx script out of it and load the url directly into xcelsius. Or sometimes I schedule the aspx script to an xml file abd pull that instead to avoid having to hit the database every time the dashboard fires.
I have a problem with the wizard queries FlyNet.
Testing with Oracle ODBC connection is ok.
But when I select any table from my db error 42S02 Microsoft ODBC Driver for Oracle. If I write the query in hand still works.
Why does not my wizard?
