I have some data in a mssql database and i want to generate reports corresponding to that data. Is there any way through which i can generate the reports directly by using the database as the input source to the xcelsius.
In the database new data is continuously getting added, so I am interested in developing some real-time application using xcelsius where it can fetch data from the database and display it on report.
Please help me either by giving direct input or by giving some links for pdfs or web pages. I am a newbee with xcelsius.
Can you be more explicit about using BO universe and the process that you are talking about?
Dont you think in order to create a BO universe I have to take a membership/subscribe to BO, which will cost me.
Someone told me that we can achieve this by using Microsoft Reporting tools Any ideas or lead on that?
xCelsius can consume web services. One method (as mentioned) is to use the BusObj Query as a Web Service. But if you have another method to create web services against your SQL Server database, you can consume that. But you can’t create a direct connection (e.g. ADODB, ODBC) from xCelsius to a database platform.
There is no way you can connect CX directly to database.You have to use a medium ie: Live Office or QAAWS , which inturn needs a business objects universe against the database.
Thanks a lot for responding back.
I am quite new with the xcelsius. I would greatly appreciate if you can give me a link to an article or some pdf that explains the process that you guys are talking about.
If possible can i have your email ids so that i can contact you directly for getting a quicker reply.
Go to the Business Objects site (www.BusinessObjects.com) and go to Support -> Documentation. Select Product Guides. Then select Business Objects XI Release 2 and Productivity Pack. One of the documents is Query as a Web Service. It’ll walk you through the technology and the integration to xCelsius.
But using QaaWS requires an installation of Business Objects Enterprise.
You don’t need Qaaws or Liveoffice or web services to get the data. You can actually get the data into Excel as a query in XML format.
If you have Excel 2003 or above from Excel go to Data - Import External data and select New Database Query.
You can similarly link to any XML file also and get the data.
Just some additional questions?
Which version off Xcelsius do you need to build? (i have standard version)
Does a user need a viewer to use for exemple a swf file?
HAAG:
If you want to Create Static Dashboards using MS Excel as your Data Source, you can use any edition of Xcelsius. However, if you are trying to create Dynamic Live Dashboards, you need to have one of the following:
Im afraid you cannot use Crystal Xcelsius Standard 4.5 to create Live Dashboards.
The Recipients dont need any Kind of a Viewer to open and interact with the Dashboards. All they need is the latest version of Adobe Flash Installed on their machine. You can download it here: http://www.adobe.com/products/flashplayer/
