I am using Xcelsius Enterprise 2008 and have created a Qaaws URL. I have then added the URL query to the
Data Manager\WSDL and clicked import. The Web Service URL populated it self.
Under the Input Values, I have 2 options Login and Password. I am not sure how this part works,
I have put in my ad login and password ie. in two seperate cells in in the embedded excel sheet
and cross referenced in the input values.
I am still testing this product so I have used the EFASHION universe. My QaaWS query is only
looking at Store_Name, this is where I am confused does this data appear in my embedded excel
sheet? If yes please can you explain how…
you have to indicate where you want the data to be inserted in your Excel sheet. Afterwards, you can base your dashboard on that. Note: you won’t see the data in you Excel sheet, its only when firing up the dashboard that the data will be inserted (if you checked ‘refresh on load’ that is)
