WSDL Issues in Data Services Designer
I have been trying to setup a WSDL Datastore to geocode account information. I ran into a problem using my WSDL service, so I tried to setup one following this tutorial for Currency:
http://www.dwbiconcepts.com/etl/23-etl-bods/158-web-service-call-in-sap-data-services.html
Jobs using both datastores fail with a similar message:
Geocode Datastore: XML Parser Failed: Error <namespace ‘https://geoservices.tamu.edu/’ is referenced without import declaration at line <11>, char <55> in <<xsd: schema …
Currency Datastore (from tutorial): XML Parser Failed: Error <namespace ‘http://www.webserviceX.NET/’ is referenced without import declaration at line <11>, char <46> in <<xsd: schema …
Data Services Designer 14.2.1.224
Given that both WSDLs have about the same problem, is there anyone that has some pointers on what to look at?
mkb_au (BOB member since 2011-10-28)
are you able to open and follow this example? :
http://wiki.scn.sap.com/wiki/display/EIM/Consuming+an+external+Web+Service
Are you creating this datastore as a web service ? or as an adapter?
For the example above, create a new data store as a web service.
use the local WSDL or “http://wsf.cdyne.com/WeatherWS/Weather.asmx?WSDL” as the WSDL URL.
ww55d (BOB member since 2011-06-14)
this is a bug, it’s fixed in
DS 4.2 SP01 Patch 3 (DS 14.2.1.622)
Thanks Manoj_d!
Where can I see what else is fixed in that patch?
Nevermind, I found the kb article.
Can you share that link?
http://service.sap.com/sap/support/notes/1985648
