system
December 1, 2009, 2:02pm
1
I have a Class- COA. In that i have 5 objects. 4 objects are coming from one table (Tab-1) and 1 object from another table(Tab-2).
I joined both of them based on proper columns values.
When i drag 5 objects into report it showing data in two tables in report and preparing two SQL statements for the same. Why??
I don’t know where i went wrong, please teach me…
BOCP (BOB member since 2007-07-02)
MarkP
December 1, 2009, 2:04pm
2
Are Tab-1 and Tab-2 related in any way?
Are they joined?
Are they joined in the same context more specifically?
system
December 1, 2009, 2:13pm
3
This sounds like incompatible dimensions.
BOCP - do you have common dimensionality in your tables?
And have you set up the contexts?
SandiR (BOB member since 2004-12-20)
system
December 1, 2009, 2:16pm
4
Its look the object from the second table belongs to different context and its generating different sql for that object.
Siva.M
looksmee (BOB member since 2006-02-08)
system
December 1, 2009, 2:34pm
5
It could also be that they have Generate a seperate SQL statment for each measure, under universe properties?
Mak 1 (BOB member since 2005-01-06)
system
December 1, 2009, 2:42pm
6
2 sql queries isn’t a big issue, but incompatible dimension would cause the data to be split into 2 tables.
system
December 1, 2009, 2:46pm
7
Always wondered why it was the default !
Agreed - the two tables bit is actually the key, in this instance - Doh!
system
December 1, 2009, 3:17pm
8
Thank you all…
I joined those two tables.
No Context defined
No where they were used(In other contexts also), am sure, beacuse i took aliases for those tables and changed object definitions and joined properly. (Because of that doubt).
Incompatable objects?? Why??
Tables Description:
Tab-1 has:
1.Acc No
2.Description
3.Class
4.Type
5.Curreny (Not used as Object)
Tab-2 has:
1.Code
2.Description
Join: Tab-1.Curreny=Tab-2.Code
To get description for all currency/codes from Tab-2.
Object Description:
Acc No ==> Tab-1.AccNo
Description ==> Tab-1.Description
Class==> Tab-1.Class
Type==>Tab-1.Type
Currency==>Tab-2.Description
My problem:
After aliasing them and repointing the changed tables in object definitions also am getting two SQL statements, why??
Please help me out…
system
December 1, 2009, 3:23pm
9
Can you copy the generated sql into here please?
system
December 1, 2009, 3:32pm
10
Hi Sandi…,Thanks!
Direct queries only. See below…
Select1:
Select
Tab-1 AccNo,
Tab-1 Description,
Tab-1 Class,
Tab-1 Type
From Tab-1
Select2:
Select
Tab-2 Description
from
Tab-2
What went wrong?? Please…,
MarkP
December 1, 2009, 3:51pm
11
After adding the join have you re-exported the universe and come out of the report and gone back in to pick up the universe changes?
In terms of the SQL you just posted, is that what was generated when you simply included all five objects in the query results?
system
December 1, 2009, 4:22pm
12
No Context defined
No where they were used(In other contexts also), am…
So what does this mean - are there contexts in the Universe?
dessa (BOB member since 2004-01-29)
system
December 1, 2009, 4:24pm
13
The actual sql as generated cut & pasted may be better to understand.
But as Mark said - have you re-exported your universe and refreshed your query.
If you have aliased your tables - can you double check that you have changed your objects to reference the alias tables.
system
December 1, 2009, 5:08pm
14
@ Mark:
–> Re-exported… YES
–> In terms of SQL… YES
@Dessa :
–> YES, other contexts are there.
@Sandi :
–> Posted query is same as generated only. Unfortunately, i can’t do copy & paste from remote desktop.
–> Re-exported and tried on new query only.
–> I repointed all object definitions to aliased tables.
Still am facing the same…
Is other Contexts making problem??
system
December 1, 2009, 5:23pm
15
The reason I asked about C&P the SQL is that the code you posted doesn’t seem to refer to an alias table.
I would have expected to see
select … from
system
December 1, 2009, 5:27pm
16
I think one golden rule has been forgotton :).
Every join must belong to a context, once you start using them, this isn’t the case here, is it?
Try the FAQ:-
https://bobj-board.org/t/15227/3
MarkP
December 1, 2009, 5:34pm
17
Are all the five objects dimensions?
system
December 1, 2009, 6:18pm
18
I would say so. and as suggested read the FAQ.
Sorry, actually the other contexts aren’t making the problem, the fact that you have joins not in a context is making the problem.
system
December 2, 2009, 4:47pm
19
Yes, Isolated join was the problem.
I added them to new context and now i can see one SQL select.
Yes, all are dimensions. Any issues ??
Thank You All.
