Why Platform section in Transformation tab is there in BODS
In BODS transformation tab, we have Data Quality, Data Integrator and Platform section.
I want to confirm why there is a need to create a Platform section in BODS even the transformation used in Platform should come in DI transformation section only.
Thanks & Regards,
Shagun Kanodia
shagun_kanodia (BOB member since 2012-09-01)
depending on your license DI or DQ tranforms will be enabled, platform trnasform are basic/core transforms that are available for both if you have DS license then everything will be enabled for DI license only DI and Platform will be enabled for DQ License only DQ and Platform will be enabled
thanks for the reply… :slight_smile:
