hi.
in all the theory related to rapid marts i’ve been seeing an external target database.my doubt is that if rapid marts can store data in a form that can directly be used to generate reports, why do we need this external target database?
thank you.
alpana.
because a RapidMart can not store data. It is just code that loads a DWH schema - somewhere. You have to provide the database the RapidMart should load.
