Which SDK for Crystal Reports of BO?
I need to integrate a java application to send report (populate parameters and schedule) to BO. The report will be viewed in BO InfoView.
The reports will be Crystal Reports.
Can someone help me on the SDK that will support the reports as also with some documentation/code samples on the same.
Jagruti
jagruti_shah (BOB member since 2010-06-21)
For what you’re looking to do, the Enterprise SDK should be sufficient.
You can find the docs, example code, and tutorials here:
http://www.sdn.sap.com/irj/boc/sdklibrary
crystal01 :us: (BOB member since 2006-08-30)
