We are currently working on migration of 4.0 jobs to 4.2 Sp1 version. Our repository in 4.0 is SQLserver and in 4.2 we built on DB2 10.1, I came across 2 methods of migration
atl import
repository upgrade
For our scenario which is best to use, any suggestions. and I am nto aware of steps invovled in repositroy upgrade, could some one give insight into these details.
we do not have sign off from Business on this requirement. and the current 4.2 installation is on brand new servers. Please let me know if we are good with atl migration or we need to go for repository upgrade too.
I plan to upgrade my BODS environment from BODS 4.1 SP1 Patch to BODS 4.2 SP1 (with the correct IPS version also)
I would like to avoid repository upgrade, but do the following way:
export my BODS 4.1 jobs as .atl
scratch my BODS 4.1 repository DB
uninstall BODS 4.1 - install new BODS 4.2 repository DB
install BODS 4.2
import my BODS4.1 .atl into the new BODS 4.2 repository
(I m not able to test it now, because I have access problems on the SAP support site since several days, that prevents me from downloading the kits/patches )
Do you think those BODS 4.1 atl will work as-they-are on BODS 4.2 without any job modification ?
Jim’s approach is the only approach to perform an actual DS UPGRADE.
There is no such thing as a “ATL Upgrade”.
Importing a DS 4.0/4.1 ATL file into a DS 4.2 repository will NOT upgrade your structures contained within those jobs to meet the new DS 4.2 structures - you are basically “ramming” the ETL script down the throat of your DS 4.2 repository and you really have no idea what the impact is. (Think square peg, round hole.)
