Repository view ALVW_PARENT_CHILD contains the ‘where-used’ relationships of BODS objects. However, when a custom function is used in an audit rule it does not pop-up there. How can I find out the ‘where-used’ of custom functions including the audit rules?
The only way I can think of is to parse/scan the language in field TEXT_VALUE of table AL_LANGTEXT. The audit rule is kept in a piece of XML:
<AuditRules>
<AuditRule RuleType="2">
<UIValue1></UIValue1>
<UIValue2></UIValue2>
<UIValue3></UIValue3>
<Custom>my_custom_function( ) = 0</Custom>
</AuditRule>
It’s quite a tedious task to do that, though not impossible.
I would appreciate an easier solution. Any suggestion is welcome!
lamanp (BOB member since 2008-09-02)
