Where on SAP sites can ADAPT info be found?
One of the more unhealthy aspects of working with Business Objects is that one has to consult a SAP site now and then - generally the navigation layout of a SAP site leaves a lot to be desired.
I try to find information of a fix for ‘ADAPT01090750’ whether it is implemented or not and in what release. I remember a couple of years ago ADAPT-numbers could be found in readme-files and sites could be searched through.
Does anyone know where on the SAP sites ADAPT number info can be found? I tried http://www.sdn.sap.com/irj/sdn and https://websmp201.sap-ag.de/support but to no avail.
Tim Janssen (BOB member since 2004-09-10)
:rotf:
This should help you:-
https://bobj-board.org/t/128655
Thanks for pointing me to the correct sub-site. Searching ADAPT-numbers is still a hassle but at least the readme-files can be found.
No worries Tim, there may be another way of getting to these, but I don’t know it…
If you have access to the service.sap.com, then go to Help&Support -> search sap notes and search for it. Other option: dowload the latest PDF of the Fixed Issues listof the BO version that you’re working with, the pdf’s are available on the ‘Support Packages and Patches’ tab of service.sap.com, all Adapt numbers are written there and described well
Regarding your Adapt Nr:
[i]Symptom
How to check whether the issue " Overriding of universe connection restrictions While refreshing the report" has been resolved
Reproducing the Issue: Product Version: Business Objects XI R3.0; O.S: Windows Server 2003
Resolution: The issue “Overriding of universe connection restrictions While refreshing the report” is resolved in fix Pack 3
[/i]
Antremons (BOB member since 2006-03-21)
