If {myTable.Agent_Status}=“Terminated” then {myTable.ADM_ID}
At whatever level you need it (report or a specific group) create a summary that is a count of this formula.
Or you can create a running total where the field to summarize is ADM_ID, the summary is Count, then Evaulate on Formula where the formula looks something like
If you need the number at the report level, then Reset Never, otherwise reset on change of the group where you need the count.
By doing First method i am getting 1713 which is right but with running total i am getting 1712 and that too if i place that in in report header or page header it is giving 0. I need the individual count to caluculate % of Terminated ststus among all status.
Running total can’t go into headers - they are calculated as the data is being processed, so they’re only available in footers. Since you need it in the header, you’ll need to use the formula instead of the running total.
