Thanks for your quick answer. Your Forum is realy great . I have following problem, I have a measure that counts the number of Layer that are assigned to specific Sack. Sack-Layer (relation is 1-Sack to Many-Layer).
I have the following sql:
Select count (disctinct layer.sack_id)
FROM sack,layer
WHERE sack.sack_id= layer.sack_id
How can i realize the Where condition in Universe Designer?.
You have aked the question in the wrong forum. So you are likely to get less / delayed response compared with when asked in the correct forum.
You need to explain more as this simple SQL to be implemented in teh universe you need to create one object in the designer and the join present between these 2 tables in the designer.
Dwayne Hoffpauir just answered this question the other day – and it seems to keep coming up so often that I have now added a Designer FAQ with the answer.
