Where are document identifiers?
hi!
i need document identifier for use it in link (iDocID parameter)
where can i find document identifier for iDocID?
leonard_shelby :it: (BOB member since 2007-05-29)
Please see the following link
DWH (BOB member since 2006-04-25)
ok (i tried to search “identifier” in search, so i didn’t found that topic)
upendar_tulluru :us: (BOB member since 2006-08-05)
Go to CMC. select folders from the options present. then click on that particular report for which you want to know the Doc id . You will be directed to a page where you can find the doc id under Filename .it would be like this. In the below example 579304 is the DOC ID
frs://Input/a_232/214/008/579304/cdz59d64bbb04d9b770.wid
