Hello ALL,
I have one Dimension called TransactionMXDate.I have Created three (Year of Transaction, Quarter of Transaction, Day of Transaction) details objects from that Dimension.
when i drag and Drop the Year of Transaction into query pannel in WEBI (TRansaction MXDAte Dimension) objects will also comes along with that Details object.
How to get rid from this Problem.?
Your help would be Helpful.
Pooja
ktm
(BOB member since 2008-11-12)
Hello,
that is the way it works. Just delete the dimension or drag and drop it back.
Zeitgeist (BOB member since 2008-11-21)
Yes, i did the same thing but y it is doing so, in our other universe we don’t have that Issue.
Any Idea to get rid of it Permanently?
Pooja
ktm
As stated, that’s the way it works. When you add a detail object to the query, it is considered “out of context” without its associated dimension, therefore the dimension is automatically added. Perhaps you are not remembering correctly about your other universe… or there is something wrong with it.
Dave Rathbun
(BOB member since 2002-06-06)
If you change those objects from details to dimensions, this won’t happen. You’ll also get the added benefit of being able to use them in a hierarchy.
MichaelWelter
(BOB member since 2002-08-08)
