Does any one know were can I get the info on this.? SAP site shows date of release for SP2 is later then Fix Pack 8? However I would like to read what in them before choosing the right one to install? Can any one point me to the correct location and let me know what is the latest release SP2 or fix Pack 8?
Hi Igor
not a simple answer.
SP2 came after fix pack (1.)8 but it only includes fixpacks upto (1.)5. It’s worth installing SP2 and then waiting for the fixpacks to catch up. SP2 has a couple of extra features that are worth having
Thanks Xavier,
Do you have a link to what’s new documentation for SP2 and 8? Sap BO site is very confusing I can not find any relevant information only installation/upgrade guides.
According to the SP2 installation documentation you can install later fix pack after you install SP2.
From SP2 installation guide
“You can upgrade to the current service pack directly from any
BusinessObjects Enterprise XI 3.1 fix pack or service pack level (for example
from 3.1 Fix Pack X to 3.1 SP2), but if your current fix pack was released
after the availability of this service pack, some of the upgrades you currently
enjoy may not have been incorporated. Therefore, we recommend that after
upgrading you also immediately apply the latest available Fix Pack.”
Did any one out there tried to install 1.8 on top of SP2?
Once you go to SP2, you should not install any fixpacks in the 1.x series.
When fixpack 2.1 comes out, install it.
Also, if you install SP2 and have more than 1 machine in your cluster you will likely encounter some problems with the scheduler. BO knows about the problem, but has yet to provide a fix.
I was just told yesterday by support that installing SP2 over a Fix Pack higher than 1.5 corrupts the installation. Anyone else getting conflicting information on Fix Packs?
I was told Fix Pack 2.1 covers Fix Pack 1.6, Fix Pack 2.2 covers Fix Pack 1.7, and Fix Pack 2.3 covers Fix Pack 1.8. Also, Fix Pack 2.3 doesn’t have a scheduled delivery date but they anticipate December 2009.
I know you were given bad info. 2.1 just came out last week. 2.2 is in mid December. 2.1 is supposed to cover up to 1.8 and then some fixes to the broken stuff in SP2.
Here’s the twist. Fix Pack 2.1 does cover up through Fix Pack 1.8, however, it’s not recommended to do an in place install of SP2 over a Fix Pack higher than 1.5. So, if you’re on Fix Pack 1.8 you should make a back up of the CMS and FRS, do a clean install of SP2 and then point to the CMS and copy over the FRS, then install Fix Pack 2.1. So XI 3.1 SP2 is the new base installation like XIr2 was the base for XI.
