What is MAPI??
I was searching for a sample code to export the report into PDF and send it through the Outlook. I have found one at https://bobj-board.org/t/15915
However, it says ’ you must install MAPI in your BCA server for it to work’. What is MAPI? I’m trying to send it through the Microsoft Outlook. Is it possible? Could some tell me what MAPI is???
I just downloaded the zip file from the location and tried to run the vba. I got and error that says ‘Can’t find a project/library’ at As MAPI.Session line (the first line).
Thank you-
thumper (BOB member since 2003-03-21)
I’m sure you’ll get a much better response later, but MAPI is a Mail API. It lets email clients talk to email servers.
MS Outlook is a MAPI compliant email client.
MAPI is Messaging Application Programming Interface. You should have a MAPI complient client, eg Outlook, Lotus Notes, Eudora etc… installed in the BCA server in order for you to be able to send e-mail using BCA.
Anjan Roy (BOB member since 2002-07-10)
This is the code (Please see the code in the bottom of this reply…) from the report that I have found from this website… If I could attach the report here, it may be more usefule, but don’t know how to attach… Anyways, when I try to run the macro, I get an error message “Can’t find project or library” at the first line, which is “Dim objSession As MAPI.Session ’ Local”.
I have Microsoft Outlook installed on my computer.
Why am I getting this error message?
Thank you four help…
thumper
Sub SendMailPDF()
Dim objSession As MAPI.Session ' Local
Dim objMessage As Message  ' local
Dim objRecip As Recipient
On Error GoTo error_olemsg
Dim doc As busobj.IDocument
Dim rep As busobj.Report
Dim DPName As String
Dim test As Boolean
If ActiveDocument Is Nothing Then
     MsgBox "NO Active Document to refresh"
  Else
    Set doc = ActiveDocument
   If Not doc.IsAddIn Then
       ActiveReport.ExportAsPDF ("C:\" & ActiveReport.Name & "_" & Format(Now, "mm_dd_yy") & ".pdf")
    Else
    End If
  End If
Set objSession = CreateObject("MAPI.Session")
'Use a profile which exists on your Exchange Server as mailid.We created bo_admin for ours
objSession.Logon profileName:="bo_admin", newSession:=False, showDialog:=False
If objSession Is Nothing Then
    Err.Raise 10, "MA MACRO", "must first log on; use Session->Logon"
    Exit Sub
    End If
Set objMessage = objSession.Outbox.Messages.Add
If objMessage Is Nothing Then
    Err.Raise 11, "MA MACRO", "could not create a new message in the Outbox"
    Exit Sub
    End If
With objMessage ' message object
    'Substitute with your subject
    .Subject = "Daily  Report"
    'Substitue with your message
    .Text = "The Daily report is attached herewith  "
    .Text = .Text & ActiveReport.Name & "_" & Format(Now, "mm_dd_yy") & ".pdf"
Set objAttach = .Attachments.Add ' add the attachment
If objAttach Is Nothing Then
     Err.Raise 12, "MA MACRO", "Unable to create new Attachmentobject"
     Exit Sub
     End If
     With objAttach
      .Name = ActiveReport.Name & "_" & Format(Now, "mm_dd_yy") & ".pdf"
      .Source = "C:\" & ActiveReport.Name & "_" & Format(Now, "mm_dd_yy") & ".pdf"
     End With
    .Update ' update message to save attachment in MAPI system
    Set objRecip = .Recipients.Add
    With objRecip
        objRecip.Name = ("grpname") 'Substitute with individual mailid or groupname
        objRecip.Type = CdoTo
        objRecip.Resolve
        End With
    With objRecip
       objRecip.Name = ("name") 'Substitute with individual mailid or groupname
       objRecip.Type = CdoCc
       objRecip.Resolve
       End With
    .Update
    .Send showDialog:=False
    End With
     Kill "C:\" & ActiveReport.Name & "_" & Format(Now, "mm_dd_yy") & ".pdf"
    objSession.Logoff
    Exit Sub
error_olemsg:
'MsgBox "Error " & Str(Err) & ": " & Error$(Err)
    Err.Raise 13, "MA MACRO", "Error " & Str(Err) & ": " & Error$(Err)
    Resume Next
End Sub
Just check if the MAPI dll’s are correctly referenced in the VBA code. Open the VBA code, go to Tools -> References and see if MAPI is referenced. If not check the box to select it and then try.
I checked add-in. I have followings checked but still get the same error message :cry:
Visual Basic For Applications
BusinessObjects 5.1 Object Library
OLE Automation
Microsoft Forms 2.0 Object Library
MISSING: Microsoft CDO 1.21 Library
Messenger Type Library
Microsoft Outlook 9.0 Object Library
Any clue? Is there a way to send a file to an Outlook without doing this MAPI ? :confused:
You are missing a dll, the CDO one. I am not sure which one that is, but is has to do with VBA. I would check, but my pc is loaded down with a job right now.
Scott Bowers :us: (BOB member since 2002-09-30)
Just check if anyone of them is attached to \winnt\mapi.dll. If not you would need to attach that.
Ok, I found C:\WINNT\system32\MAPI.DLL. However, when I try to add it by “Tools”-“References…”-“Browse”-“C:\WINNT\system32\MAPI.DLL” and “OK”, I get an error message, which is “Can’t add a reference to the specified file.”
:nonod:
Sorry for this bother…
I really appreciate your help…
thumper
Thumper,
Did you check the registry to ensure that your MAPI.dll and CDO.dll are properly registered (I would also double check the other DLLs)? If not, you could run “regsvr32” at the command line, followed by a blank, followed by the name of the DLL you would like to register.
Judy
JMulders :us: (BOB member since 2002-06-20)
I think that is because you already have a reference to it with the outlook reference. The problem is the CDO reference dll missing. Here is where it is on my machine, I am in 2000, yours might be in a slightly different place.
C:\Program Files\Common Files\System\Mapi\1033\NT
You would also need to add a reference to both “Microsoft Exchange 5.5 ACL Type Library 1.0” and “Microsoft CDO 1.2 library” or “Microsoft CDO 1.21 library”
A few useful links could be
here, here and here
I dont think you need the exchange reference unless you are working on the actual exchange server, I have never used that dll. The CDO dll is missing, or in a different location from the person that wrote the module. In one of the posts there is this:
Get that straightened out and the code should work. Do a search for cdo.dll, then just go to the references and browse for the dll under that refreence.
Scott
Thank you! It worked fine finally. I was able to find the location of the CDO, manually browsed it and added-in.
Thank you all for all the help! :stuck_out_tongue:
thumper
