What format does a date filter need to be in Crystal 2008
I am using 01/01/2005 00:00:00 as the date format for a filter in Crystal but I am getting the following error:
Failed to retrieve data from the database.
Details ORA-12801:error signalled in parallel query server P122, instance gl03dm05:ewp11(1)
ORA-01861:literal does not match format string
Any ideas what the correct format should be?
Thanks!
Blowers (BOB member since 2009-09-30)
May I ask how you define the date filter? Did you use the parameter then place it under record filter or directly place date under record filter.
nahtanoj :philippines: (BOB member since 2009-07-08)
If using a parameter there are 2 options: date and datetime. Make sure you select the right one.
The date format is yyyy-mm-dd and the datetime format is yyyy-mm-dd hh:mm:ss
mtoedtemeier (BOB member since 2008-07-18)
