I am working on a table with a column having XML files as content.
when i try inserting the table ,while creating the universe , the column doesn’t appears in the left pane of the designer
so i created an object of the same name in designer , under the table but i culdn’t specify object type -as XML as there was no such option ,and then exported that universe.
when i use the object in query execution–it gives error of “not supported data type”.
what data type should i specify for the column containing xml content or is there any other way of bringing that column in inserted table
