What are impacts of changing longname or filename of a univ
What are the impacts of changing the filename or the longname of the universe on reports.
Rajiv1107 (BOB member since 2007-01-25)
hi
when you try to change the filename then,
universe throws warning stating that you have to change the universe name too as the same universe already exists…
hence you cannot export the existing universe.
judia
judia (BOB member since 2008-06-24)
Hi Judia, Good morning.
I did not get what the issue is.
I have changed the universe name and universe folder name in CMC and
imported from the repository.
But I did not get any error. Please clarify my doubt.
Kamalini :india: (BOB member since 2007-10-11)
hi kamalini,
good afternoon.
when you try to change the filename of the universe in the designer.
you will get this warning.
judia
@Rajiv1107:
You could have searched with keywords ‘universe name’ or ‘universe long name’ in the semantic layer forum
Found these
Thank you Judia and Haider,
For your needful information :smiley:
