Weighted Contribution in Match
Hi there!
I was hoping someone could help on the match transform. I am trying to get data services to return a low match score (say 50%) when 2 telephones numbers match 100%.
The reason for this is that I would like to do the same for email, then name, then address all with equal contributions.
The setting I use are:
BREAK KEY = FIRST NAME
MATECH CRITERIA = TELEPHONE
MATCH SCORE = 101 (to make it the match not the only criteria)
NO MATCH SCORE =-1 (to make the match not the only criteria)
WEIGHTED CONTRIBUTION = 50
USE IN WEIGHTED SCORE IF MATCH > = 50
EXCLUDE FROM CONTRIBUTION IF MATCH < 50
This way I am pretty sure I am saying if the match is 100% then contribute 50 to the overall score. So where in the data the telephone is 100% I should get a match score of 50.
However, it returns 100 rather than 50!
I am a bit stuck, if some one could help that would be amazing! Thanks!
greg123 (BOB member since 2013-05-16)
Hi Greg ,
Weighted score calculation based on contribution of the field. If you give the contribution for the telephone number 50% and remaining fields 50% it should calculate the similarity score based on the contribution only .
Please share me your sample input records and contributions .
Thanks & Regards,
Ramana.
Ramana :india: (BOB member since 2009-04-30)
Hi Ramana,
What is similarity score in match transform?
Will it be internally generated? or do we need to enable that in match transform settings?
Durai
DbUoRdAsI :india: (BOB member since 2012-05-08)
Hi Durai,
Similarity score will be generated internally. We don’t have any control on similarity score.
Thanks & Regards,
Ramana.
Thanks a lot Ramana.
