Hello - We are working on pushing data via webservices SOAP adapter but getting error - we made necessary change to axis file ( axis file in E drive and DS installed in C drive). Testing in soap UI working -
pls suggest -
ERROR in axis log -
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *request_uri_based_dispatcher added to the index 0 of the phase Transport
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *addressing_based_dispatcher added to the index 1 of the phase Transport
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *rest_dispatcher added to the index 0 of the phase Dispatch
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *soap_message_body_based_dispatcher added to the index 1 of the phase Dispatch
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *soap_action_based_dispatcher added to the index 2 of the phase Dispatch
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *dispatch_post_conditions_evaluator added to the index 0 of the phase PostDispatch
[datetime[debug] …\src\core\engine\phase.c(121) axis2_handler_t *context_handler added to the index 1 of the phase PostDispatch
[datetime[debug] …\src\core\deployment\conf_builder.c(234) No custom dispatching order found. Continue with the default dispatching order
[datetime[debug] …\src\core\deployment\conf_builder.c(379) Module addressing found in axis2.xml
[datetime[error] …\src\core\deployment\conf_builder.c(877) Specifyingservices and modules directories using axis2.xml but path of the library directory is not present
[datetime[error] …\src\core\deployment\conf_builder.c(262) Processing transport senders failed, unable to continue
[datetime[error] …\src\core\deployment\dep_engine.c(939) Populating Axis2 Configuration failed
[datetime[error] …\src\core\deployment\conf_init.c(195) Loading deployment engine failed for client repository E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name\axis2.xml
Error in MC -
There is no response for the web service . Ensure that the network, web server, and service are running properly. Also ensure that the service client call time out is set properly. ( when axis path NOT mentioned in Data store i.e. in E drive
Creation of web service client for the web service failed. Check log file <C:\ProgramData\SAP BusinessObjects\Data Services/log/axis2_log.txt>. ( when axis path mentioned in Data store i.e. in E drive)
Thanks Manoj - I made the change and tried - this time job dying abnormally -
Data flow <DF_1> received a bad system message. Message text from the child process is <ᅳ========================================================================================================>. The process executing data flow <DF_1> has died
abnormally. For NT, check errorlog.txt.
log error -
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *request_uri_based_dispatcher added to the index 0 of the phase Transport
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *addressing_based_dispatcher added to the index 1 of the phase Transport
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *rest_dispatcher added to the index 0 of the phase Dispatch
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *soap_message_body_based_dispatcher added to the index 1 of the phase Dispatch
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *soap_action_based_dispatcher added to the index 2 of the phase Dispatch
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *dispatch_post_conditions_evaluator added to the index 0 of the phase PostDispatch
[datetime] [debug] …\src\core\engine\phase.c(121) axis2_handler_t *context_handler added to the index 1 of the phase PostDispatch
[datetime] [debug] …\src\core\deployment\conf_builder.c(234) No custom dispatching order found. Continue with the default dispatching order
[datetime] [debug] …\src\core\deployment\conf_builder.c(379) Module addressing found in axis2.xml
[datetime] [debug] …\util\src\class_loader.c(140) E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/lib/axis2_http_sender.dll shared lib loaded successfully
[datetime] [debug] …\util\src\class_loader.c(140) E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/lib/axis2_http_receiver.dll shared lib loaded successfully
[datetime] [info] No files in the path E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/services.
[datetime] [debug] …\src\core\deployment\dep_engine.c(1283) axis2_dep_engine_load_module_dll: DLL path is : E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/modules/addressing/axis2_mod_addr.dll
[datetime] [debug] …\util\src\class_loader.c(140) E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/modules/addressing/axis2_mod_addr.dll shared lib loaded successfully
[datetime] [debug] …\src\core\deployment\dep_engine.c(1283) axis2_dep_engine_load_module_dll: DLL path is : E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/modules/logging/axis2_mod_log.dll
[datetime] [debug] …\util\src\class_loader.c(140) E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/modules/logging/axis2_mod_log.dll shared lib loaded successfully
[datetime] [debug] …\src\core\deployment\dep_engine.c(1283) axis2_dep_engine_load_module_dll: DLL path is : E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/modules/rampart/mod_rampart.dll
[datetime] [debug] …\util\src\class_loader.c(140) E:\Program Files\SAP BusinessObjects\Data Services\ext\webservice-name/modules/rampart/mod_rampart.dll shared lib loaded successfully
[datetime] [debug] …\src\core\phaseresolver\phase_holder.c(139) Add handler AddressingInHandler to phase Transport
[datetime] [info] [rampart][rampart_mod] rampart_mod initialized
[datetime] [debug] …\src\core\phaseresolver\phase_resolver.c(139) Service name is : ANONYMOUS_SERVICE
[datetime] [debug] …\src\core\phaseresolver\phase_resolver.c(723) Module name is:addressing
[datetime] [debug] …\src\core\phaseresolver\phase_resolver.c(2058) Trying to add this handler AddressingInHandler to system pre defined phases , but those handlers are already added to global chain which run irrespective of the service
[datetime] [debug] …\src\core\phaseresolver\phase_holder.c(139) Add handler AddressingOutHandler to phase MessageOut
[datetime] [error] …\axiom\src\parser\libxml2\libxml2_reader_wrapper.c(305) Error occurred creating XML stream reader
[datetime] [error] …\neethi\src\util.c(37) Out of memory
[datetime] [debug] …\src\core\clientapi\op_client.c(888) Start:axis2_op_client_infer_transport
[datetime] [debug] …\src\core\clientapi\op_client.c(954) End:axis2_op_client_infer_transport
[datetime] [debug] …\src\core\engine\phase.c(210) Invoke the handler AddressingOutHandler within the phase MessageOut
[datetime] [info] Starting addressing out handler
[datetime] [debug] …\src\modules\mod_addr\addr_out_handler.c(133) No action present. Stop processing addressing
[datetime] [debug] …\src\core\transport\http\sender\http_transport_sender.c(246) ctx_epr:https://namedev.name.com/guest.do?SOAP
[datetime] [debug] …\src\core\transport\http\sender\http_transport_sender.c(805) using axis2 native http sender.
[datetime] [debug] …\src\core\transport\http\sender\http_sender.c(416) msg_ctx_id:urn:uuid:1495f825-751e-4c51-8171-559f7414fb6d
[Mon Nov 23 11:49:44 2015] [error] …\neethi\src\util.c(37) Out of memory
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\phaseresolver\phase_resolver.c(377) Module rampart will be engaged to ANONYMOUS_SERVICE
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\phaseresolver\phase_resolver.c(139) Service name is : ANONYMOUS_SERVICE
[Mon Nov 23 11:49:44 2015] [error] …\src\core\phaseresolver\phase_resolver.c(575) Handler RampartInHandler inclusion failed for Security phase within flow Security. Phase mightnot available in axis2.xml
[Mon Nov 23 11:49:44 2015] [error] …\src\core\phaseresolver\phase_resolver.c(580)
[Mon Nov 23 11:49:44 2015] [error] …\src\core\phaseresolver\phase_resolver.c(445) Engaging module rampart to operation OPERATION_ROBUST_OUT_ONLY failed.
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\clientapi\op_client.c(888) Start:axis2_op_client_infer_transport
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\clientapi\op_client.c(954) End:axis2_op_client_infer_transport
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\engine\phase.c(210) Invoke the handler AddressingOutHandler within the phase MessageOut
[Mon Nov 23 11:49:44 2015] [info] Starting addressing out handler
[Mon Nov 23 11:49:44 2015] [debug] …\src\modules\mod_addr\addr_out_handler.c(133) No action present. Stop processing addressing
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\transport\http\sender\http_transport_sender.c(246) ctx_epr:https://name.link.com/imp_user.do?SOAP
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\transport\http\sender\http_transport_sender.c(805) using axis2 native http sender.
[Mon Nov 23 11:49:44 2015] [debug] …\src\core\transport\http\sender\http_sender.c(416) msg_ctx_id:urn:uuid:b766dbc3-f89b-43f6-8f5d-30ab8c9c04d9
