Webservices..Importing issue
First time i am working on webservices.
Client is given one url.I have created one datastore with that url.
But clicked import option i got error like in the attachment.
Inside url we have xsd schema as well as xml schema.
Any one help me out.
Thanks in advance.
Siva.dwh (BOB member since 2008-11-13)
what is the Data Services version ?
you are using Adapter Datastore or Native WebService Datastore to import the funtions from WSDL
check the WSDL, from the error the WSDL parser is not able to resolve the type definition, is this is public WSDL ? without looking at the WSDL its hard to tell whats missing or how to work around
check the following link with a similar issue
