WebIntelligence Storage Location Change
Hi all.
Have just completed the installation and setup of a test Business Objects environment consisting of Business Objects 5.1.4/WebIntelligence 2.7.
Everything is currently working fine with that.
I would like to change the storage location of users InfoView documents to another server.
So far I have tried:
  • Stopping WebIntelligence
  • Specifying a different Storage location using the WebIntelligence Setup application on the Business Objects server
  • Re-start WebIntelligence
When I log into InfoView and open/refresh a new document it appears that WebIntelligence is still reading/writing from the original <C:\Program Files\Business Objects> location, not the specified network location.
Re-starting the server makes no difference either.
I have the correct rights to read/write to the new location, I just don’t think WebIntelligence is even getting that far.
Any ideas would be appreciated.
Cheers!
veybo :australia: (BOB member since 2006-08-22)
Got it.
I had to change System Environment Variable WIStorage to also point to the new location and then re-start the server.
Cheers!
