Webi3.1 report issues after universe re-pointing
Hope everyone doing good.
I am facing a problem in web intelligence3.1. We have made few changes in the universe and exported after renaming.
When we repoint this webi report to new version of the universe, report lost its merged dimensions and even variables are also changed.
Ex: V_policyname:- ="=[actual variable definition]"
Really wondering why this is happening when repointing the report.
Thanks in advance.
GCB343 :india: (BOB member since 2008-09-19)
yes I’ve had that happen. The merge dimensions get screwed up. Then if your variable was referencing the merged dimension that got removed then that would get messed up too. I don’t know any way around this… just a ā€œfun featureā€ of webi, as I understand it.
erik.stenson :us: (BOB member since 2012-07-30)
Hi Erik,
Which version of business objects you are using?
same as you
