WebI WIS Customization
I’m in the process of customizing the WebI look & feel by combining features of the SDK and updates to the *.WIS files. Everything is working perfectly until I drill into a document. When I do that, the DefaultRPage.WIS takes over my window; the generated HTML has target=_top. I want it to remain in a specific frame but I can’t seem to find how to change the target.
Anyone have success or ideas on how to keep the drill-down confined to a specific frame?
Hi Richard,
I don’t have a solution to your problem, however I am interested in what your are doing.
Do you have any documentation or any material on the wis files? Can you send me a description of what you are doing and how you combine the SDK?
A big limitation for me is the lack of ability to use the full client documents wheh using the SDK, how do you deal with that?
Ronen Baran, eBusiness Project Manager
Tecnomatix LTD.
Mail to : rbaran@tecnomatix.com
Telephone : 09-9594959
