Does snap to grid work in WebI? It doesn’t seem to do anything on mine.
Quite annoying when I’m trying to align everything so it doesn’t look weird when output to Excel.
NK
nk81 (BOB member since 2011-11-03)
NK
works, here is how.
Example, Right click on a table and select the snap to grid option
Doing just this will not make the table snap (it will only make you snap - )
After you do this…(and cool down) try to move the table a little into anygrid and you will see that when you do this the table will snap into the upper left corner of the grid.
Make sure you have enabled the grid to be displayed.
All the best !!
Naresh Ganatra (BOB member since 2004-04-09)
It seems to be working…after a while.
It wasn’t really “snapping” correctly at first. The block would snap on the middle of a grid, or 1-2 grids away. I moved the block around a few times and it eventually decided to start snapping into the upper left corder.
Weird…
