Environment: SQL Server 2000, Webi Rich client 12.4.0 built 966
I have a weird problem with a database connection through OLE DB. I have one connection that is used in 2 universes, say universe A and B. From my own system (webi 12.3.0) I can connect without problems with both universes and get data.
On other systems (webi 12.4.0) I can connect and get data through universe A but not with universe B. Because they use the same connection is seems very weird.
The error I am getting is:
Database error: [Microsoft OLE DB Provider for SQL Server] : Multiple-step OLE DB operation generated errors. Check each OLE DB status value, if available. No work was done.(Error: WIS 10901)
Other info: DeskI works without problems, I can view the SQL code in Webi so the universe can be reached.
Input appreciated!
HenkK
HenkK (BOB member since 2004-03-02)
