I have a requirement to include dimension values in a single field…something like below,
Report is like this now,
SO number Serial Numbers
12345678 AWE123
12345678 AWE122
12345678 AWE125
98765432 QWE123
98765432 QWE126
98765432 QWE129
34567890 SDF4566
34567890 SDF4534
34567890 SDF4500
and this is how the user wants.
12345678 AWE123;AWE122;AWE125
98765432 QWE123;QWE126;QWE129
34567890 SDF4566;SDF4534;SDF4500
Basically all the serial numbers under a particular sales order should be in a single line. I have attached an excel file that shows it a bit more clearer.
Can any one provide some suggestions, how we can achieve this?
I can’t think of a way to do this a the reporting layer but you can do it at the universe layer if the so# is a separate object from the serial number. Define the serial number as a sum measure and then concatenate a “;” to the end of the object.
