Webi Report in Users Inbox and Personal Folders
Is there a way we can find out all the Webi reports present in users inbox and favourites folder.
Ankit
at&t (BOB member since 2007-04-05)
in BOXIR2, go to CMS>>objects. A whole listingof reports is displayed along with other details. All the reports that have the folder as userFolders> <> are te reports present in user’s personal folder.
priyanka1410 :uk: (BOB member since 2007-01-13)
You mean CMC, I think, not CMS :wink:
yes, CMC :slight_smile:
Thanks for your reply, Actually I want to create a excel report with following columns
  1. User name
  2. Folder (Inbox/Favourites)
  3. Webi Report Name.
I know that using CMC I can see the user reports, but I want to document all of them , so I was just thinking if there is a Auditor Report or Query Builder Query or some other way to get the same information instead of manually looking at each users folders.
Thanks again,
Ankit
Any Suggestions Friends?
Hi Ankit
I have a suggestion for you using query builder. First I would like to know how many user folders are there in your system? If it is not too large you can try this.
You should get a list of all SI_ID’s of all user folders. You can use this query for this
select si_id from ci_infoobjects where si_kind=‘Inbox’
And you can use those SI_ID’s in the second query which is something like
select si_name,si_owner from ci_infoobjects where si_parentid in (SI_IDuser1,SI_IDuser2,SI_IDuser3,…SI_IDuserN) and si_progid=‘CrystalEnterprise.Webi’
I hope this helps if you don’t have too large users.
Raul… :united_arab_emirates: (BOB member since 2007-07-31)
