Webi publication produces blank reports
I have created a Publication that uses a Webi report as the Data Source (that uses a BEx query) and a Dynamic Receipient Webi report that uses an Excel file (that is saved on the BOBJ server). Both Webi reports run as expected and I get the correct data. When I run the Publication the receipients get a blank report. When I run in Test mode, I get one file that displays all of the data and each Dynamic receipient file is blank.
Anyone know what’s going on here? I’m using version 4.1 SP4 Patch 4
billo83 (BOB member since 2007-01-16)
When you run a publication it produces a log file, instead of the instances you see on standard schedules. Are there any clues in this file?
No it shows as successful. I’ve attattached a sreen shot of the log file
