Dear,
I used versions 5.x, 6.x for the last 7-8 years and really felt at ease with it.
Now since a few months I’m using Webi in XI3.1 Edge and I miss a lot of the functionalitly I used to have in the desktop environment.
- slice and dice panel
- query filtering on the result of another query
- calculations are more limited
- copy/pasting in webi is cell per cell, in desktop you can copy/past entire row
- more options on breaks/section in desktop
…do you agree with me or am I missing something?
As a developer, it’s quite ok as it’s my job and I can find a workaround for some things in order to let the report do what it’s expected to do. But for an end-user, I find that the Desktop environment was more user friendly.
What are your thoughts?
MichM3 (BOB member since 2005-06-07)
