Webi issue
Following would be a simple example to explain.
Suppose x axis has 4values, let’s say 2 4 7 10, and y axis has 4 corresponding values, let’s say it’s same like x axis 2 4 7 10, then the graph will be a straight line. When x is 15, we can assume y is also 15. If I had to draw the graph manually, I could just draw a straight line without knowing x or y beyond x=15.
Basically I’m using what I know and extending it to what I don’t know.
I would like to know if it is possible in webi.
Neha.k
neha.k (BOB member since 2012-02-12)
Hi ,
The nature of the graph will depend on the values of the Catagory Axix and the Value Axis., and also the type of graphical representation you have chosen.
It seems from your statements that you are looking for a Line graph.Now if the values for your Catagory Axis and the Value Axis forms a straight line , that will obviously bee shown on your graph.
Please let me know if this answers your question.
Sud
sud317 :canada: (BOB member since 2010-08-02)
Thanku for your reply,
let me check
Also look at the Interpolation() function - I think it fills in gaps between values and has a couple of modes to control how the ‘fill in’ numbers are generated with respect to the ‘real’ numbers.
So in other words u wanan base base your future trend based of your cureent numbers…so in a period of time if you revenue is increasing by 1 % you want your future resulkts to increase by that factor. is that so ?
Thanks & regards,
:mrgreen:
AFAF :india: (BOB member since 2012-07-13)
