I’d like to thank everyone that responded to this. As it turned out, removing all of the registry entries (and yes, there were a lot), then reinstalling on a new partition did the trick.
I also agree with Anita below, In an ideal world, yes it would be great just to FDISK, Reinstall NT/Server and start over, but due to the cost structure of test servers, we’ll always have to find more dilligent ways to upgrade our servers because other apps are installed.
Thanks again,
Christopher J. Pohl
Mellon Financial Corporation
Corporate Information Systems Group/SED
From: Nather, Tom (CAP, PTL) [SMTP:Tom.Nather@PENSKE.COM]
I agree. Not all of us have that kind of cash…
The easiest process I have found is when upgrading clear the registry of all
references to BO. I know no one wants to mess with the registry but it works.
One other thing is to blow away all directories under program files. This makes sure that all programs are the latest and greatest. The install has a
problem recognizing newer versions. Keep in mind don’t do this on a master
install.
When doing a master install just get rid of all BIN directories. This is where all the dll and exe files get stored.
This works since I just did the 2.5.2 upgrade from 2.5.1.
Sincerely,
Tom Nather
Data Warehouse Group
Penske Logistics
email:tom.nather@penske.com
At 01:14 PM 4/14/2000 -0700, you wrote:
I would like to suggest that when upgrading a production server, it’s
best
to do a completely fresh installation on a completely different machine
with
a new, fresh installation of NT. Upgrading a production installation of
any
type of server application on Windows NT is just a bad idea, in my experience.
This would be a good idea if one has lots of machines and lots of money. We happen to have a very small user base on WebI, and we have only one machine. We had to beg to borrow an existing server for testing; since
we don’t own it, we can’t wipe it clean. And when we upgrade the production machine, we have to upgrade it in a very short period.
So the bottom line is that starting over may be practical for some folks. Figuring out upgrade workarounds may be more pragmatic for others (like us).
Anita Craig
