Webi instances become lesser after migration
Hi, we have upgrade our BOE XIR2 to XI3.1 recently, and we found out the most of the reports instances (used to be more than 15).
After migrated, all the reports with instance before have maximum 15 instances only…any idea?
ylai20 :malaysia: (BOB member since 2008-05-21)
Are you sure that you do not have this limit set in the 3.1 destination system?
How should i check?
By the way, if i increase the limit in XI 3.1 now, will the rest of instance come back??
Its a setting in the CMC, sorry, I’m not in front of my system just now.
I would imagine you will only get them back, if you re-import the reports…:).
