Hello,
I’m looking for the PAR of webintelligence 2.6, especially the operation system available
Can somebody tells me where i can find this?
thanks for your help.
kakounj (BOB member since 2004-05-14)
Hello,
The PAR for that really-old version 2.6 might not be available on tech support any more. (You would have to log in with your tech support userid, if you have one.) I seem to recall that the last time that I checked, just 5.1.8/2.7.4 and 5.1.9/2.7.5 were available.
However, if you have the installation CDs, I believe that there’s a copy of the PAR there, I think it was on the second of the two CDs.
Bobarella (BOB member since 2004-02-12)
Technical support site
peacock (BOB member since 2002-11-07)
