I am trying to create a WebI report with a hyperlink to another WebI report based on the value of a feild. I have it almost working, but the last part has me stumped. I have searched BOB, BusinessObjects Tech Support, Tech Tips, the 2002 User Conference presentations and BO documentation on all CDs I have. I probably have missed something simple.
I have a master report that has a hyperlink column in it based on a universe object. It is supposed to link to a detail report in the repository that has the same object in it with a prompt on that object. I run the master report and get an error screen “Please reply to all prompt(s) before running the query:”, I select the appropriate value and click “Run Query” and the detail report is generated. How do I eliminate the error screen?
Unfortunately, yes; that was one of the many issues I solved thanks to posts here. This is the first time I have tried this and I got most of my info from BOB.
I believe, and I am not certian, that it is an error in the way I am trying to fill the prompt for the detail report.
When I was playing around with this last summer, I found out that there were different values in the syntax for non-SDK installations. And the syntax you present looks like it might be the SDK version – although I think Steve said the syntax may have been switching around in the last couple of service packs.
At any rate, here is a post with they syntax that I was able to get working without SDK.
Good job, Lee. There’s nothing like making a big fuss over a situation, only to find out that we caused it by some silly mistake. I’m quite experienced at that.
