Webi has lots of blank space on right side
One of Webi reports in Xi R2 is leaving lots of blank space on the right side. This is our property settings:
Page Size: Letter
Page Orientation: Portrait
Margins (all 4 sides): 0 px
We tried changing the page size to A4, we tried changing the orientation to Landscape, nothing works. we don’t see the space in the edit mode. But for some reason when we view the report in the view mode, it shows almost one extra page worth of space on the right side of the report with nothing in it.
Beats me as to why it would do that. :hb: :hb: Any ideas?
bits06 :us: (BOB member since 2006-04-21)
Try to display the report in “Structure view”
then look for a cell which should be left blank …
Perhaps…
internettefr :fr: (BOB member since 2006-07-17)
goto the struture and page layout mode and try to adjust the margins and everything.
You should always go to the structure mode to adjust the report.
Vellachi
vellachi (BOB member since 2005-07-11)
Like I had mentioned in my first post:
We do not see the space when we are in Edit mode. So even in Structure mode, I don’t see any extra blank space on the report document. Everything is perfectly fine. Margin’s are set to 0 on all 4 sides.
This thing happens only in the view mode and not in the edit mode. And once in the view mode, I can’t view it’s structure.
Couple of things you can try:
  1. Make sure that you don’t have any cells that are going out of the page limits when you view in the page layout mode. I had a similar issue where webi was adding additional blank pages after every page. Found out that one of my cells was going outside the page boundary by a few pixels and it added the extra pages.
  2. Try setting the margins to a different non-0 value.
Farhan Jaffery :us: (BOB member since 2005-08-27)
Margin settings of zero are probably a bad idea. Most printers can’t print right up to the edge of the paper.
Did you look at your document in page layout view? This is where it lets you edit your header and footer. Perhaps there is a cell in one of them that is causing the empty page to the right.
nathanebht :us: (BOB member since 2004-02-05)
Hi bits06
How did you finally solve this issue .I am getting the same problem ,in edit mode , everything seems to fit in page ( i am using landscape ) Whereas in view mode I am seeing the blank
As suggested by others I did try looking for a blank cell ,incase I had any …in structure .But there doesnt seem to be any. I do have margin pixel as 70 pt
could not figure out where I am going wrong :shock:
Learnitwithease (BOB member since 2005-01-12)
I have not solved it yet, but I think the reason is because my table is extending in another page (horizontally) and that is leaving lots of space.
I will post here the solution (if I find any…) :frowning:
I am experiencing the same probleme, with afaik no cell/blank cell going out of the page limits.
So if anyone has find the reason/solution to that probleme, i m interested.
Bobuser5 :fr: (BOB member since 2006-06-01)
I had the same problem in that the report would print two pages and the second page was blank.
I traced it back to a table that had the property - Center across page.
When I removed this the report only had one page.
Hope this helps
SandyG (BOB member since 2006-07-04)
Hope this helps
Typically, a cell can be just a bit outside of the margins - even if BO doesn’t say so. Try resizing or moving cells a little closer to the center of the page and see if this makes the blank page go away.
Mr Anderson :norway: (BOB member since 2006-03-29)
I can’t find the ‘Centre across page’ option in the properties against the report. Can someone describe where this is located.
Cheers.
mjyoungman :australia: (BOB member since 2006-10-06)
FINALLY!!
Found out what was causing so much grief, turn off “enchanced viewing” for the report (go to document properties when in edit mode).
Phew!
Woo :canada: (BOB member since 2003-04-24)
you made my day!!
Maverick002 (BOB member since 2012-06-26)
