heh what a pain…I have asked out IT dept to schedule the box to bounce weekly…crossing the fingers.
Ian,
We are experiencing the same problem. First our configuration:
Webi 2.5.2
NT 4.0 svc pack 4
IIS 4.0
Oracle 7.3.4 running on a HP 9000 system
We have a Master install on a dual 400 mhz Pentuim III Compaq Proliant 5500 server and a Node install on a quad 200 mhz Pentuim Pro Compaq Proliant 5500 server. RAM is 640 MB and disk storage of 25 GB on both machines.
We were experiencing problems where the ‘system’ is down in the mornings. On a side note, the Oracle database is brought down for nightly backups and the HP9000 is rebooted to clear memory/buffers.
The problem centered around Webi allowing you to login, but you could not open a report.(Other times WEBI is down completely, meaning no logon screen is available). To fix this problem, we would shutdown both systems, Node then Master. Then we would start the Master and then bring up the Node. We were doing this manually every morning until we set up two automated processes using the ‘AT’ command.
We use ‘AT’ to shutdown and restart Webi. The WIMANAGER and the WIORB processes are stopped and started using a ‘net stop’ and ‘net start’ command.
This seemed to fix our problem, but then we starting experiencing problems with the ‘system’ being down every other day, in no particular frequency.
Using the NT Resource Kit CD, we are shutting down Webi using the before mentioned process. This is done before the Oracle database is brought down.
After the HP9000 is backuped and rebooted, we then reboot both the Master and the Node server, using the ‘Shutdown’ command located on the NT Resource Kit CD, and then start Webi using the before mentioned process. The ‘AT’ command drives all of these processes.
Currently our situation has stabilized and we are not having the same problems with Webi not working in the mornings.
We also, on occasion, see the similar issue that Webi goes down (Dies) during the day, and we have experienced the phenomenon where a WIQT process starts taking all of the RAM and not releasing, which brings ultimately brings Webi down. This situation normally takes place on the Node server. To correct this problem, we shut the Node down, and reboot the system. It seems to correct the problem, until the next time it does it. We have logged a call to Tech Support, but to no avail…
Is anyone else out there encountering these types or problems??? If so, what are you doing to correct/work around them?? Any and all information would be appreciated…
