WebI 6.51 : WIJ 2002 error when creating a WebI document
In WebI, when I try to create a document with a Universe I get the WIJ20002 error when the applet is starting. I get this error with each of my universes I used.
The Administrator Console is working fine.
My configuration is :
OS : Windows 2003 Server
WS : IIS 6
BW : IE 6
Please, any idea ?
cocov6 (BOB member since 2003-10-31)
If you go to the Universe directory in the nodes and delete the universes that are stored in that folder. Then go the designer and import and re export the universe. Then when you go into Webi it will reload the universes again.
irish_stan :ireland: (BOB member since 2003-05-13)
I faced the same problem recently, but that seems to be related to my new XML key file. see my reply in the other thread https://bobj-board.org/t/33779
dont know if it applies in your case. hope this helps
Peeyush
peeyush (BOB member since 2005-03-04)
