Web service(QWASS) Issue in Dashboard
Hi Experts,
I have developed dashboard using Web service connection(Qwass). it gives me following error when i pass prompt value from dashboard to webi report.
Please help me. I googled it a lot but still not got any proper solution for same.
System Details:
SAP BO 4.0 sp6
Xcelsius 2008
OS: Solaris
Thanks & Regards,
Atulm
atulm (BOB member since 2012-06-30)
I suggest that you use a tool like Fiddler to check the traffic that the dashboard is sending. I suspect that it is not sending the prompt value you think it is.
Thanks for reply and suggestion.
This error occurs first but, if you wait for moment then it gives me proper data from web service.
Please suggest.
Thanks & Regards,
Atulm
I can’t be sure without Fiddler logs, but that sounds a lot like the web service is firing off once with bad prompt values, and then again with the correct prompt values. I’d check the cells where you are getting your prompt values, and the cells you are using for your triggers.
Hi Lugh,
Thanks For reply.
It working fine now.
Best Regards,
Atulm
