I have recently upgraded from 4.5 to Xcelsius 2008 and am having trouble getting the Web Service Connections set up correctly for my QaaWS.
I have 7 LiveOffice connections in a model that seem to all refresh on load fine and i have already set up a Web Service Connection that picks up the drill through path of what the user has clicked on and used them as input parameters to a QaaWS query.
I now need to add another Web Service Connection for another QaaWS and i get the following error message;
“Unable to Load URL”
I have checked the available QaaWS services using dswsbobje/qaawsservices and the 2 queries appear as i would expect.
I have checked the dsws.properties file and the user name and password are correct (which i would expect as teh 1st connections works in the Xcelsius model.
I have restarted the Tomcat server and CMS and this does not cure the problem.
I have even tried re-installing QaaWS.
I have installed SP1 fix 1 for 2008. I am currently using XIR2 SP2.
Can anyone help as sometimes this functionality works and sometimes it does not. The 2 queries i want to use point aty teh ssame database and BO Universe.
anthonyjones (BOB member since 2008-03-10)
