Hello All,
We are having a problem with our XI R2 install, relating to opening OLAP documents (pulling data from MS Analysis 2000 cube on seperate server) in the CMC
We are working with tech support, but they can’t recreate the problem on their end (but have used WebEx and have seen the problem occurring.)
Essential info:
Server Platform: Windows Server 2003 w/ SP1
Installed Products:
-BOE XI R2 - Java w/ Tomcat (IIS is installed & running, but www service is disabled. Also, Tomcat is configured to answer requests on port 80)
-OLAP XI R2
-CR XI R1 w/ latest CR XI update.
In InfoView, DHTML and ActiveX both work for OLAP documents. Assuming that DHTML is selected within InfoView as the OLAP viewer, then in the CMC, OLAP docs open with all viewers. Here’s where it gets strange. If I go back to InfoView and change my OLAP viewer to ActiveX, then only the DHTML viewer works when I try to preview OLAP documents. If I try to use any other viewer in the CMC to preview OLAP, I get the following error page:
WCA unknown error
Message:An undefined exception has occurred in the plugin
Stack Trace:
com.businessobjects.enterprise.wca.impl.WCAException$UnknownException:
at com.businessobjects.enterprise.wca.impl.internal.WebComponent.process(Native Method)
at com.businessobjects.enterprise.wca.impl.internal.WebComponent.process(Unknown Source)
at com.businessobjects.enterprise.wca.servlets.a.a(Unknown Source)
at com.businessobjects.enterprise.wca.servlets.WCAControllerServlet$DefaultStrategy.apply(Unknown Source)
at com.businessobjects.enterprise.wca.servlets.WCAControllerServlet.service(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:237)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:157)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:214)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:104)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:520)
at org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:152)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:929)
at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:534)
It gets better… If I go back to InfoView (didn’t even have to log out) and switch my OLAP viewer back to DHTML, I can go right back to CMC (didn’t even have to log out of that either) and now the other viewers work!
I’ve tried logging out and back in after making selections, but no-go. It seems that having the ActiveX viewer selected as preferred viewer for OLAP in InfoView somehow affects how the viewers work in CMC (sounds like it can’t be possible? Well, support verified that this seems to be the case.)
Oh, and Crystal Reports don’t seem to be affected by this at all, no matter what is selected as the CR viewer in InfoView or CMC, Crystal Reports seem to work just fine.
Anyway, I know that R2 is still so new, but if anyone has come across this and found a way to fix it, I would really appreciate hearing how, or even what the deal is with this.
Many Thanks,
Chad
CFetzer
(BOB member since 2005-12-15)
(BOB member since 2005-12-02)
