If you can do this, then enlarge the cell to the size you want, maybe remove the borders, and place it over all the other tables. Then select the cell, select Format > Placement > Send to back.
I did the procedure you had said, (placement -> send to back), its working for the charts (as the member had mentioned).
The same process when you do it for a table, the image disappears. Attached is an example. The member wants a water mark behind the table. Meaning both thetable data and the image should appear merged without distrubing data. Or i can say the efashion logo should be transperent. GIF images would allow transperency but GIF are not supported in BO.
Everything you did is perfect - you just need to do a few more steps. Select all cells in the table, and select FORMAT CELL. Select the SHADING tab. Under FILL, select the radio button labelled NONE.
This is an issue that BusinessObjects needs to address, there is no way of securing a BusinessObjects Report. I can create one in any spreadsheet or word processor that looks identical. To ensure that reports are those produced by BusinessObjects I would like a standard way of having a watermark on a template.
I think that you are wrong about that type of security being a problem for BO to address. Any printed image can be replicated using a sophisticated enough drawing package and printer. The points at which security should be applied are database access, and physical security such as real security watermarks/other features in the actual paper.
If you consider the most likely items to be reproduced illegally( money) it is the physical security measures that are hardest to beat, not reproducing a convincing image.
I agree totally, I never said that it would be the definitive answer to counterfeiting, but it would go along way towards making it more difficult for the average type user :? . In our situation, we have over a thousand managers who run monthly BusinessObjects reports and most of them would have the ability to duplicate a report, some of them do, just to re-arrange the layout even though it is supposed to be a standard corporate report. If we could fairly safely imbed our corporate report watermark then at least we do have a certain level of security.
The number of people that do break into secure things is usually inversely proportional to the strength of the security.
On Monday 4th September 2006, God said “Crikey, what are you doing here”
Goodbye Stevo.
